setting up SLM on M800
Discussion and support for MoTeC's Shift Light Module
Postby C4a0s on Sat Feb 14, 2009 7:52 pm
hi all,
i recently purchased a SLM (yay!! :mrgreen: )and hooked it up to my M800 (spending quite some time to fabricate the wires and using the black heat shrink thingy to make everything as professional as the SLM wires, yes i'm a perfectionist :geek: ). however when i tried to test it using the SLM table and rpm as the Y-axis, nothing happened. :cry:
then i realised that there is a "Adjust/General Setup/Communications/CAN Setup" :shock:
are we supposed to set it up here? cos mine is blank and previously i just used the CAN for USB connection to my laptop.
if so, can we just use any channel for SLM transmit? Data would be, 13 and Address would be...41?
help pls :cry:
C4a0s
Re: setting up SLM on M800
Postby Mazi on Sat Feb 14, 2009 8:16 pm
Yes! :D
SLM CAN Setup copy.jpg (61.64 KiB) Viewed 33720 times
Mazi
Postby C4a0s on Sat Feb 14, 2009 9:31 pm
OMG!!! :shock: the SLM is SO BEAUTIFUL!!!! :mrgreen: with 8 different colors... droolz..
thanks mazi.. :lol:
the other shift lights etc all pale in comparison
C4a0s
Postby IJ. on Sun Feb 15, 2009 9:19 am
I have mine plugged into an SDL and if you like it on the 800 you'll go nuts over what it can do on the dash :)
Brake fail
High Beam
Left turn
Right turn
Park brake
Rev Limiter
WB Trim rich max
WB Trim lean max
Methanol Injection active
All with their own patterns/colours and brightness and dimming with the headlights on.
IJ.
Postby C4a0s on Sun Feb 15, 2009 12:43 pm
oh yes... i heard from mark mccoy abt the crazy shit we can do...BUT..the ADL, SDL are all so expensive :cry:
C4a0s
Postby figgie on Thu Feb 19, 2009 8:50 am
C4a0s
no no no.
The SDL is what IJ is talking about.
The ADL2/ACL goes even FURTHER in the SLM control.!
figgie
Postby C4a0s on Thu Feb 19, 2009 10:40 am
yup figgie.. but my point is...they are all so so expensive. :(
even more than an M800 :shock:
else i would have gotten a ADL2 and PDM and... :mrgreen:
C4a0s
Postby figgie on Sat Feb 21, 2009 6:53 am
The SDL should be cheaper than the m800. The ADl2 on the other hand is quite pricey!
figgie
Postby C4a0s on Sat Feb 21, 2009 7:20 pm
figgie.. "quite pricey" is an understatement :mrgreen:
in some places, u can buy a car with that!! :shock:
C4a0s
Postby trainwrex on Thu Apr 01, 2010 11:39 pm
Just wondering if anyone has a sdl program that they can send me or attach to this forum that has all the shift light conditions such as indicator ect..
Im not sure how to set it up??
trainwrex
Return to SLM
