How many different layouts are there to chose from without using display creator and are there any pictures anywhere. I have only seen 2 and wasn't sure if that was all or there are more and if the color scheme was fixed for each layout
There are 10 different standard templates for the C series displays, with 16 pre-configured colour schemes. These colour schemes can be modified to suit your needs as well.
Stephen Dean MoTeC Research Centre Melbourne, Australia
If you download any of the C series Dash Managers, and go to the Display Setup window (I), and click on the Change... button (II), you can see the list of display layouts available.
Display Setup.PNG (35.56 KiB) Viewed 10999 times
I've downloaded the software and started exploring all the options. One thing I couldn't work out is if it is possible to deacticate the large digit that is usually used for gear position. Ideally I would like to have used that gor road speed but being a single digit that isn't going to be an option
