Retractable Headlight Control
Postby HKS_TRD on Sun Sep 15, 2019 12:18 am
Based on the schematic below, will I need to use one PDM output to raise the headlights and then a second output to drive the motor to lower the headlight.
The logic of when to raise and lower the headlights is a whole other can of worms based on two inputs but in the first instance I'm trying to determine if driving the motors directly will require more outputs than powering them through the integration relay
Headlights 1.gif (134.25 KiB) Viewed 9559 times
HKS_TRD
Re: Retractable Headlight Control
Postby HKS_TRD on Sun Sep 15, 2019 12:23 am
A little more info on the functionality of the headlight system
Headlights 2.gif (85.71 KiB) Viewed 9557 times
HKS_TRD
Postby adrian on Tue Sep 17, 2019 9:30 am
How much of the wiring that is shown in that schematic is still in the car?
If it is all there then all you do is feed the entire circuit with a single output from the PDM. If there are parts missing then it gets a bit more difficult to replicate the functionality but it should be possible.
Postby HKS_TRD on Tue Sep 17, 2019 10:00 am
All the wiring is still there, so that is an option.
That integration relay also controls the headlight auto off function which disrupts the power to the coils of the headlight and tail light relays. That is one of the few creature comforts of the car I want to keep so its steering me towards keeping the integration relay if I can work out how to interface the PDM with the auto off feature
HKS_TRD
Postby Ae92 on Sat Oct 02, 2021 12:22 am
Hello did you have any luck with this ? I'm looking to remove the headlight wiring on my ae86 and have the motec pdm30 control the headlights
Ae92
