Hi All
On MoTeC Mx00 series user menu say 500mm is the maximum distance from CAN device to the trunk.
What happens if I have the CAN device is 1m from the main CAN bus?
Thanks a lot!
David Ferguson wrote:
Instead of splicing onto the trunk, break it there and extend both legs until the are within 0.5m of your device, splice at that point. Often you can make this right at the back of a connector for a device.
