SKM on M400
SKM and OKM
SKM on M400
Postby Martin on Fri Nov 28, 2008 12:44 am
Is it possible to use Lambda2 to read the SKM`s knock voltage output on a M400?
Re: SKM on M400
Postby Dragon on Fri Nov 28, 2008 9:24 pm
Yes. La2 is actually preferred.
If you are using a M400, do you have a spare ign output channel to be configured as "knock window"?
Dragon
Re: SKM on M400
Postby Martin on Sat Nov 29, 2008 2:58 am
Yes,
Inj8 Is dedicated in the M400, and M600 for Knock Window. M400 is the only Mx00 ECU without a second Lambda. Its only got 1 Lambda input. What i would like to know is if its a software limitation or would La2 Vs work for an input for "Knock Voltage" ?
Re: SKM on M400
Postby Martin on Thu Feb 12, 2009 4:32 pm
Motec?
Re: SKM on M400
Postby OmarK on Tue May 05, 2009 12:21 pm
Hi Martin,
This version: M400 M600 M800 M880 ECU Manager V3.51M2 allows Lambda2 sens to read the SKM`s knock voltage output on a M400 now. This is pin B12.
OmarK
Re: SKM on M400
Postby Martin on Tue May 05, 2009 3:33 pm
Thank you Omar
Return to Knock Modules
