i have on-going issues starting when cold, and then 'getting away"
it is a track only car using a 2GR V6 Toyota engine and running E85. Once warm/hot, its mostly fine. its below about 20C ET or around 0-10C AT, where i'm having issues
My ET and AT sensors appear to be giving sensible results
Ive read other related posts and cant get a handle on this. in particular, in my table on fuel crank % trim , the values that have been set by the tuner are many times higher than MOTEC HELP suggests and what others have published when discussing this topic (see attached screen dump).
my air temp compensation is exactly as per MOTEC HELP, eg 4% at 0C and even if i double that, it makes no difference. My Ignition AT compensation is also exactly as per MOTEC HELP, but i've yet to try to adjust that.
I would be grateful for any comments/guidance
