SDL Info
SDL Info
Postby Vlad on Sun Jul 14, 2019 9:08 pm
Hy Adrian, i want to get this dash for my own project car, ca you tell me what options are enabled and if it’s backlit or not? Kind regards, Vlad.
Vlad Pescaru
Vlad
Re: SDL Info
Postby Stephen Dean on Mon Jul 15, 2019 10:50 am
Hi Vlad,
That is a Backlit SDL with the following enabled.
SDL # 25552
Options
29230:ENABLE
29214:LOGGING (8M)
Re: SDL Info
Postby Vlad on Mon Jul 15, 2019 3:39 pm
Thank you!
Vlad Pescaru
Vlad
Re: SDL Info
Postby Vlad on Fri Jul 19, 2019 2:18 am
Dose this dash need an external inverter for the backlight? Or dose it have it built in?
Thank you again!
Vlad Pescaru
Vlad
Re: SDL Info
Postby David Ferguson on Fri Jul 19, 2019 7:04 am
It's built-in to the SDL and later backlight dashes.
Re: SDL Info
Postby Stephen Dean on Fri Jul 19, 2019 9:25 am
Hi Vlad,
As David said, this is a Dash with the backlight built in, hence the part number of 18010, the SDL Displays without the backlight have the part number of 18009.
Return to ADL, ADL2 and SDL
