OBD and MoTeC ?
OBD and MoTeC ?
Postby PQatPIT on Wed Feb 04, 2009 9:48 am
Hello gentlemen!
Is it possible to install MoTeC Mx00 or newer models and have OBD port active? This is needed for yearly car inspection, nothing else.
If not possible with MoTeC is there some other decent priced solution I could suggest to a customer?
Thank you in advance!
PQatPIT
Re: OBD and MoTeC ?
Postby PQatPIT on Mon Feb 09, 2009 10:35 pm
Ehh, no info here? Somebody must know how to do OBD-2? With MoTeC?
Thanks!
PQatPIT
Re: OBD and MoTeC ?
Postby RossB on Tue Feb 10, 2009 8:31 am
MoTeC ECUs do not have an OBD-2 function. Our ECUs are intended primarily for motor sport use where OBD-2 diagnostics are not a requirement. The calibration of OBD-2 diagnostics in a factory ECU is vehicle specific and any modification you make to a car is likely to have an effect on it.
RossB
Re: OBD and MoTeC ?
Postby stevieturbo on Thu Feb 12, 2009 10:25 am
Could it work if you piggy'backed the Motec into the car, and left the OE ecu running in the background to provide an OBD output ?
Or would unplugging the coil/injectors etc from it make it throw errors ?
stevieturbo
Re: OBD and MoTeC ?
Postby PQatPIT on Fri Feb 13, 2009 2:16 am
stevieturbo wrote: ...the OE ecu running in the background to provide an OBD output ?
Well, although it is 2002 JDM car there is no OBD II to even start with. If there would be then I'd do it changing it once a year to OEM spec bofore inspection, and back after that.
Thank you everyone. Maybe the owner will keep it as a track toy for now.
PQatPIT
Users browsing this forum: Majestic-12 [Bot] and 8 guests
