evinrude emm e tec
evinrude emm e tec
Postby valegas on Sun Jun 30, 2019 6:58 am
hello, i'm using a really high perfomance M130 on my 4 cyl tyrbocharged. now i want to play on a v6 e-tec direct injection evinruder marin engine. no way to use my M130 also coupled to very complicades emm from evinrude?
thanks
valerio
valegas
Re: evinrude emm e tec
Postby Stephen Dean on Mon Jul 01, 2019 10:45 am
If the OEM Evinrude ECU directly controls the injectors and pump for the DI fuel system, then the M130 will not be able to drive the injectors as it does not have the required injector driver hardware. For this you would need to use either an M141 or M142, dependent on the way that the injectors are driven.
Users browsing this forum: Bing [Bot] and 26 guests
