System Files M1
System Files M1
Postby Donovan CR6 on Thu Jun 27, 2019 11:00 pm
Where do I find the system file location for M1, mine is saying its missing or corrupt since I installed m1 tune on a new laptop?
Donovan CR6
Re: System Files M1
Postby Stephen Dean on Fri Jun 28, 2019 10:27 am
The files are located in C:\ProgramData\MoTeC\M1\System, as the ProgramData directory is normally hidden, you will need to turn on the "Show hidden files and folders" option in the version of Windows File Explorer that you are using to be able to see this directory. With M1Tune closed, you can go into this directory and delete all of the files contained within, and then restart M1 Tune, this will then do a check for updates and offer them to you.
Re: System Files M1
Postby Donovan CR6 on Wed Jul 03, 2019 1:36 am
I found it under C:\Appdata
All working now :D
Donovan CR6
