Idle Control without Ignition Control.
Postby rayhall on Wed May 22, 2019 9:27 pm
I have the M150GPR on a Audi V10 with one DBW throttle body. I want the idle control to not use the idle ignition control as well as the DBW control. Can this be disabled so the main ignition table is been used.
I am finding the way it switches between idle ignition and the main table destabilising of the idle quality.
Ray.
rayhall
Re: Idle Control without Ignition Control.
Postby David Ferguson on Thu May 23, 2019 2:14 am
I suggest you disable the idle ignition control by setting Idle Ignition Timing Limit Advance Control Proportional Gain (and Integral Gain) to 0.
Postby Stephen Dean on Thu May 23, 2019 4:56 pm
Hi Ray,
Post some logging and the config (or email it to support @ motec.com.au) if you would rather, and I see if there is a way that we can get the idle working correctly with the ignition control.
