Failed To Update Calibration
Postby Loqy on Tue Apr 23, 2019 8:44 pm
Hi everyone,
I'm new with the M1 ecu.
When I 'Check for Updates' all the updates are :
- Systems (2)
- Calibrations
- M1 Application
See attached picture :
WhatsApp Image 2019-04-23 at 16.22.37.jpeg (30.97 KiB) Viewed 9249 times
All the files has been successfully updated except the Calibrations
WhatsApp Image 2019-04-23 at 16.14.07.jpeg (80.37 KiB) Viewed 9249 times
Here are the few questions that I'm holding :
- Is that Windows problem ? I already turn off Firewall & Antivirus, but still not working.
- Is it M1 software problem ? Because I already use other laptop but still not working.
Any post will be highly appreciate.
Loqy Siregar
Loqy
Re: Failed To Update Calibration
Postby Stephen Dean on Wed Apr 24, 2019 11:03 am
I see that M1 Tune is also prompting for you to update to 01.04.0.200, can you please do this and then retry the Check for Updates.
Also, do you have M1 Build installed?
Postby Donovan CR6 on Thu Jun 27, 2019 11:38 pm
Mine is doing the same, can't figure it out :cry:
Donovan CR6
Postby Stephen Dean on Fri Jun 28, 2019 10:43 am
If you have M1 Build installed can you ensure that it is the latest version as there is a difference between the location that M1 Build and M1Tune stores the calibration files. This was bought on by Microsoft making a change to the way that file permissions are done in the user profiles.
The files are stored in C:\Users\UserName\AppData\Local\MoTeC\Calibrations, if you go into this directory (as the AppData directory is hidden you will need to turn on the "show hidden files and folders" option in File Explorer) and delete all of the files and folders in it, the next time that M1 Tune is restarted it will do a check for updates and reprocess the retrieve.
Postby Loqy on Thu Sep 19, 2019 7:45 pm
Already upgrade to M1 Tune 1.4.0.200 and M1 Build 01.04.00.0185
But still not working
I'll try the other way that you've explained.
Thank you, really appreciate.
Loqy Siregar
Loqy
