ref/sync mode 53 with the M16A
Postby eddie_h on Mon Jul 26, 2010 7:25 pm
is mode 53 the correct oem mode to use with the suzuki M16A engine.
crank trigger wheel is 36 teeth with 2 missing 3 times.
eddie_h
Re: ref/sync mode 53 with the M16A
Postby RossB on Thu Aug 26, 2010 12:05 pm
THis should be the correct mode for this engine as used in a Suzuki Swift.
RossB
Postby Tunedgether on Fri Mar 08, 2019 5:59 pm
Do you have PID for E-Throttle and Cam Control this engine?
Regards,
Tunedgether
Postby Stephen Dean on Tue Mar 12, 2019 9:34 am
If you can post the part number of the DBW I can look it up and see if we have done a calibration on it.
Cam PID's really need to be done for each engine, changes in manufacturing tolerances and oil viscosity will make a big difference to the numbers used.
Postby Tunedgether on Fri Jan 28, 2022 5:19 am
SDean wrote:Hi,
I would like to PID for Bosch E-throttle 0280.750.156.
Advance Thank You,
Tunedgether
Postby Stephen Dean on Fri Jan 28, 2022 9:02 am
We have a calibration for this DBW throttle, but I only have access to the calibration for the M1 that doesn't readily translate back to the M800 values. The tech that does the calibrations for the DBW's is out of the office today, but I've asked him to follow up on this when he gets back in on Monday for you.
Postby Tunedgether on Thu Feb 03, 2022 6:18 pm
SDean wrote:Hi,
Thanks for reply, waiting for your reply again.
Tunedgether
Users browsing this forum: Bing [Bot] and 14 guests
