by dr350 on Wed Jan 30, 2019 8:12 am
Hi
Again thank you very much!!
I was doing tests, with the can communication, M142-PDM30, and I can not operate the CAN.Fuel.Pump.Primary channel.
The tests are performed from the ecu, with the option "TEST" from M1.
Enables the correct low output but the channel is not activated (always at 0)
CHANNEL Configuration:
CAN.Fuel.Pump.Primary 8bit 11A hex 0 40 hex (as in the list)
Performing the same tests with COOLANT FAN, they work correctly:
CAN.Coolant.Fan.1: 16
CAN.Coolant.Fan.2: 8
Also perform the tests with the following channels and they work correctly:
CAN.Neutral.Switch
CAN.Clutch.Switch
CAN.Brake.Switch.
Thanks!!
Regards!!!
