Bmw e9x m3 Abs sensors To m1(solved)
Re: Bmw e9x m3 Abs sensors To m1
Postby karel021 on Tue Oct 10, 2017 7:46 am
Ben-S wrote:That's actually normal, these sensors use an encoder in the bearing that allows them to determine direction of rotation. You should be able to filter it out.
Okay :)
i did Pm you.
if you have any drawing or some sketch how you wired them and also what resistor you used.
then we can try it :)
karel021
Postby karel021 on Thu Mar 01, 2018 9:12 am
A short update.
the M3 sensors wont work.
Tried them in all different ways.
however for the front sensors its possible to use any other e9x sensor as long as they are not M3.
they will fit and get a signal from the orginal m3 hub.
trying to work a custom solution for the rear
karel021
Postby karel021 on Fri Jun 29, 2018 3:32 am
An update
We got it to work
Not with the m3 sensor but one other sensor that fits good :)
Does anyone know how many teeths the wheel have ? :)
karel021
Postby karel021 on Thu Jul 05, 2018 9:12 am
Summary.
The stock abs m3 sensor sends a pulsetrain of 6-7 pulses so it hard to translate.
In the front a stock 320d sensor Will work. Fits without mods.
In the rear we found also a working one that fits.
Tooth are 48 per revolution
Will update with motec settings when it will be up and running .
karel021
Re: Bmw e9x m3 Abs sensors To m1(solved)
Postby Blu302 on Wed Jul 11, 2018 10:02 am
Just a simple question,
Do you still have the ABS module fitted?
It sends the individual wheel speeds out via CAN in 1 message and there should be at least a single wheel sent out via a wire with 1 pulse per rev.
Blu302
Blu302
Postby karel021 on Mon Jan 28, 2019 11:46 pm
Blu302 wrote:Just a simple question,
nope i didnt, i think it would be easier to have that still in the car.
but im buildning a new car now with custom uprights so i will put a standard sensor there.
i got the M3 hubs to work with a sensor from an older 5 series.
karel021
Previous
Users browsing this forum: No registered users and 46 guests
