CAN to PLEX 102pro dash
Postby harky on Sun Jan 27, 2019 8:14 am
Hi all
i am using the Plex 102 pro dash
can anyone advice me on the CAN settings. ( in the M 84 )
thanks for any help
harky
harky
Re: CAN to PLEX 102pro dash
Postby rntechnologies on Mon Jan 28, 2019 6:58 pm
The M84 has a locked dataset, so there isn't much in the way of configuration available on the ECU side.
Firstly, you will need to set the VCS/PDM address in the ECU to a free available channel. Then, in the Plex you will need to set up all of the received information from the MoTeC dataset.
Below is a picture of the CAN dataset for use in a PDM.
Regards,
Ryan
Powertune Australia
rntechnologies
Postby harky on Tue Jan 29, 2019 1:56 pm
thanks for your response
i am learning more , mainly that i don’t know what i should be doing
yep there is few options to “ turn on” CAM
and the configuration in the plex will be my next test
harky
harky
Return to M84 ECUs
Users browsing this forum: No registered users and 42 guests
