by Stephen Dean on Fri Jan 18, 2019 1:33 pm
The Engine Speed Limit State is showing as Drive Shaft Speed, if you allocate a resource to the Transmission Drive Shaft Speed Sensor Resource to make the parameters visible, you will see that the Transmission Drive Shaft Speed Engine Speed Limit is set to zero, change this to a value of 10000, save the change and then un-allocate the resource to hide the Transmission Drive Shaft Speed Sensor parameters, and then try starting the engine again.
