C187 Display Mode Change by map switch
Postby BoehmK on Sat Dec 22, 2018 12:20 am
I would like to change the Display Mode (Race, Practice, Warmup) using a map switch that outputs scaled voltage from 0-5V. Is this possible?
Thank you in advance!
BoehmK
Re: C187 Display Mode Change by map switch
Postby David Ferguson on Sat Dec 22, 2018 3:46 am
I think the easiest way is to use the "Options..." button on each of the display page setup.
You can enter conditions to enter that page. For example (VoltageSwitch > 0.5 and VoltageSwitch < 0.6). Do that for each page.
Postby BoehmK on Sat Dec 22, 2018 4:32 am
I will give that a try. Thanks for the tip.
BoehmK
