M130 looking for e46 m3 dbw characterisation
Postby chuckk on Fri Oct 19, 2018 3:23 am
I am currently looking for the characterisation to properly run an e46 M3 DBW actuator. If anyone is willing to share I would appreciate it a lot.
thanks
chuckk
Re: M130 looking for e46 m3 dbw characterisation
Postby Stephen Dean on Fri Oct 19, 2018 8:12 am
Do you have the part number for this DBW motor? If you can post it I'll see if we have characterised it.
Postby chuckk on Fri Oct 19, 2018 2:57 pm
Hi Stephen,
Here it is
13 62 7 840 537
Thank you !
chuckk
Postby super7 on Mon Nov 26, 2018 5:52 am
SDean wrote:Hi,
Hi.
Do you have characterised for 13 62 7 838 085
super7
Postby Stephen Dean on Tue Nov 27, 2018 10:19 am
We haven't characterised either of those DBW throttles, we don't actually have a lot of BMW component calibrations.
Some of the BMW throttles do also have a Bosch part number, I can look that number up if it is available.
Postby super7 on Tue Nov 27, 2018 9:01 pm
Hi Sean.
If I turn the question then?
Which BMW throttle engine have you characterized?
Sincerely, Nils-Erik
super7
Postby Herrubermensch on Sun Dec 09, 2018 4:11 am
Amazing the information that gets lost over time. Just look up the in Motec DBW-4 Manager, it's a Pierburg DBW motor (pn 7831529). Here is Motec's own characterization for it:
Proportional gain: 100
Integral gain: 50
Derivative gain: 140
PID period: 2
Dead band: .3
Feed fwd gain: 30
Integral P clamp: 40
Integral Negative clamp: -1%
Max volts: 12.8
Frequency: 8k hz
--Peter
PS: I am not positive as to how to fill out the remainder of the control table for this DBW motor in M1Tune, but I know at least two cars successfully using the above settings and leaving the rest of the table blank.
Herrubermensch
Postby Herrubermensch on Sun Dec 09, 2018 4:39 am
At least one M1 Tune configuration for the E46 M3 DBW throttle body motor I have seen uses the following variation:
P: 100
I: 40
d: 100
Integral negative clamp: -30%
Feed fwd: 10
Volts: 14
Herrubermensch
