GP V1.10 issue
GP V1.10 issue
Postby greenamex2 on Wed Dec 05, 2018 8:39 am
Any idea how to get rid of this?
greenamex2
Re: GP V1.10 issue
Postby greenamex2 on Wed Dec 05, 2018 8:44 am
Config (so far, engine not run yet...not even finished sticking it together yet...still learning!)
GPA (M130) [01.10.0010, February 2016] EX2 V6 GPA , EX2 V6 GPA 1.m1pkg-archive
(1.8 MiB) Downloaded 991 times
greenamex2
Re: GP V1.10 issue
Postby David Ferguson on Wed Dec 05, 2018 9:33 am
I would just enter a valid value for a LIN baud rate. I know it's not needed (since there is no LIN bus on the M130), but you asked how to fix that.
Re: GP V1.10 issue
Postby Stephen Dean on Wed Dec 05, 2018 9:48 am
Thanks for reporting this, I have logged it as an issue for the developers to investigate. It will not cause any operational issues for the M130, other than the error shown.
Hi David, That will not fix it, it needs a code change.
Re: GP V1.10 issue
Postby rntechnologies on Wed Dec 05, 2018 12:02 pm
I haven't had a proper look at 1.10 yet, however this is the same issue as the rs232 error messages appearing on the M130 with the older versions.
The root of the issue is that the firmware contains the modules for LIN and RS232 whilst the hardware does not have this capability in the M130.
The fix as Stephen mentioned is to actually remove these modules from the package or adding code to allow them to be disabled completely.
Regards,
Ryan
Powertune Australia
rntechnologies
Re: GP V1.10 issue
Postby greenamex2 on Thu Dec 06, 2018 9:13 pm
Thanks one and all.
Not a big issue for me at the moment...too busy making engine mounts!
greenamex2
Re: GP V1.10 issue
Postby greenamex2 on Thu Jan 31, 2019 5:12 am
Sorted. The firmware issue NOT the engine mounts!
greenamex2
Users browsing this forum: NathanB and 6 guests
