Math Expression Editor Help!
Postby supercharged_1 on Wed Oct 24, 2018 5:51 pm
I need help. I am looking to make a function to only show data when it is in the negative value. For example, the range of my channel is from 3 to -2, but I only want the graph or numbers to show from the 0 to -3 range.
supercharged_1
Re: Math Expression Editor Help!
Postby David Ferguson on Thu Oct 25, 2018 4:43 am
I would do this as:
choose (MyChannel < 1, MyChannel, invalid())
Postby adrian on Thu Oct 25, 2018 8:45 am
Just to add to David's comment, this is only possible if you are using i2 Pro. i2 Standard only lets you use +, -, x, / operators.
Postby supercharged_1 on Thu Oct 25, 2018 12:00 pm
Thanks David. That works perfectly!
And yes, I am using i2 Pro.
supercharged_1
