shift counter
Re: shift counter
Postby insomnia on Thu Jan 29, 2009 9:14 am
Hi Busaman,
i can give you a sensor who work with precision...
we use it on a GSX-R1000K4 to K8 in the German SBK..
i think you can build a mounting plate and it's possible to use it behind
the clutch basket...
The sensor as a value from 0 to 5 Kohms and work like a TPS sensor...no
hesitate between two gears...no chance to go through 0....
If you want i can send you a picture on your PM...
i hope this help...
Best Regards
Francois
insomnia
Re: shift counter
Postby RossB on Thu Jan 29, 2009 9:49 am
I have put in a feature request for this function for the Mx00 ECU and will let you know if or when it can be implemented.
RossB
Re: shift counter
Postby Brad on Thu Jan 29, 2009 7:09 pm
RossB wrote:I have put in a feature request for this function for the Mx00 ECU and will let you know if or when it can be implemented.
Excellent thanks for your help
Brad
Previous
