Are you using your own custom package, or one from a different developer?
rntechnologies wrote:Are you using your own custom package, or one from a different developer?
rntechnologies wrote:I just managed to have a look at the JRR package for you.
Under All Calibrate>Vehicle>Acceleration the options to set the lateral, longitudinal and vertical sensor resources are available.
This means you can mount the ECU as you require, and just assign the channels to the correct resource.
