motec m400 electronic throttle adjust table
Postby Caroline on Tue Jul 11, 2017 12:51 pm
I active motec m400 drive by wire option, I want to use it to control electronic throttle.
However, this is my first time to use this option. what puzzles me is the adjustment of parameter and table.
Expect a reference table. Thanks a lot. :cry:
Caroline
Re: motec m400 electronic throttle adjust table
Postby Stephen Dean on Tue Jul 11, 2017 6:12 pm
Please find the attached DBW setup notes.
DAD0001 Drive by Wire_Electronic Throttle Setup.pdf
(318.48 KiB) Downloaded 1832 times
Postby JulianEdgar on Wed Jul 19, 2017 9:31 pm
Thanks very much for this Stephen.
JulianEdgar
Postby MarkMc on Tue Dec 12, 2017 8:27 am
Just be aware that document does not cover the settings of the PID, feed forward, etc. It is best to send us the part number of the throttle you wish to use and we can provide you with the correct settings. If we have not done a particular throttle you can send it in and I can get a set up for you. The calibration of the throttle is a little involved and needs to be done correctly.
Postby Tunedgether on Mon Jul 09, 2018 1:06 am
I need DBW setup data for Honda Brio (L12 Engine). Part Number GMD4D T12000020384.
Regards,
Paisan R.
Tunedgether
Postby Stephen Dean on Mon Jul 09, 2018 10:01 am
Hi Paisan,
We have not done this throttle body, are you able to organise to send it to us through your local authorised MoTeC dealer for calibration?
Postby Tunedgether on Mon Jul 09, 2018 5:14 pm
Thank you for reply.
I am in Thailand.
How can I contact a dealer?
Regards,
Tunedgether
Postby Stephen Dean on Mon Jul 09, 2018 6:19 pm
This is the details for our dealer in Thailand.
https://www.motec.com.au/dealers/dealersasia/#Thailand
Postby Tunedgether on Mon Jul 09, 2018 7:34 pm
Can I send throttle body direct to you? I think that's a faster way.
Tunedgether
Users browsing this forum: Bing [Bot] and 12 guests
