Hello
I have a M800 connected to CDL via Can
Whilst I have everything else from the M800 working on the CDL I can't seem to get Gear position to display.
It just says "N"
I've selected 2 for Sensor in the M800 gear detection setup & put all the voltages for each gear. The Gear Sensor Voltage pin is set to AV4 (gearbox sensor) in Input Setup.
I'm unsure if I still need to put a calibration in & do a table even though I've put all the Voltages in the Gear detection setup. Although I did try this with no change. not sure if I had the right calibration chosen. I used 5V
I've gone into the CDL setup & whilst I can see the Gear sensor Voltage change with gear shifts it wont display gear number.
It wont let me change anything in the Gear Detection in the CDL as it says gear calibration is already set.
If anyone can let me know what I'm doing wrong it would be appreciated.
