by Stephen Dean on Tue Jun 12, 2018 2:07 pm
Can you confirm if it is the PDM15 (Plastic TYCO Connectors) or PDM16 (Autosport Connectors) that you are using.
If it is the PDM15, then you will need to use two pins (20A output) for the fan, if it is the PDM16, then a single wire on one of the 20A outputs will work for the output supply capacity.
With the wire gauge, how long is the run from the PDM to the fan, and what will be the duty cycle of the fan?
