hello
can be done use racegrade keypad to switch datalog enable on motec m800 ecu ?
i will buy later pdm15 for my race car
so is there any way to do it
thanks
adrian wrote:You won't be able to use the keypad directly with the ECU due to the CAN messaging structure used by the keypad.
With the keypad connected to a PDM you will be able to re-transmit the keypad button status out of the PDM in a format that can be used with the ECU. However, it will also be dependant on what other CAN traffic and devices you have sending CAN messages to the ECU on whether you will be able to get it to work.
adrian wrote:Our webinars on setting up CAN are a good start, you can find them here
If you have specific questions after that then I can help out, otherwise I suggest taking it to your local MoTeC Dealer. They will be able to configure it correctly for your particular setup.
Users browsing this forum: Bing [Bot] and 12 guests
