PDM Module broken since update
Postby NBR on Mon Jun 04, 2018 6:52 pm
Hi Guys,
Just wanted to report that with the latest PDM module update, there seems to be an issue with the mandatory tags not being set against; Count Down, Serial Number, and Firmware Version, meaning that projects that use the new module will not compile as we cant change the tags on the channels in the locked modules.
Cheers
NBR
Re: PDM Module broken since update
Postby NBR on Mon Jun 04, 2018 6:59 pm
I should also mention that the 'Control' module version 1.12.033 still has issues also (to do with the boost, gives an error about the module version being invalid), reverting to version 1.12.032 fixes it though.
NBR
Postby Stephen Dean on Tue Jun 05, 2018 10:41 am
Thanks for reporting this, I have logged this as an issue to be resolved.
Postby Stephen Dean on Tue Jun 05, 2018 11:33 am
If you do a Check for Updates in Build, there is a new PDM Module that resolves this issue.
Postby NBR on Wed Jun 06, 2018 9:36 am
Perfect, thanks Stephen
NBR
Return to M1 Build
