wire and create table for ford 2 wire IAC motor
Postby The Flash on Wed May 23, 2018 5:54 am
Hi
i have a M600 and im about to wire up a FORD IAC
can some one show me how to set up the table to control the idle?
also i am a noob so if you can explain it with a bit of details i would appreciate it
thanks
The Flash
Re: wire and create table for ford 2 wire IAC motor
Postby Scott@FP on Fri Jun 01, 2018 12:13 pm
The ones I've used have a recirc diode built in, so polarity matters.
Its just a PWM valve, so pretty much any output can be used. Set up as PWM idle control (function #2), in parameters- 160 Hz, polarity 0, output mode 0. In Functions, Idle Control, setup- what worked for me is Proportional = 0, Integral = 0.050, Derivitive = 0.10. Fill out the normal position table with values close to what is needed, I used Idle Aim Y axis, ET X axis. Min/max DC for this valve should be about 10% min, 80% max.
Scott@FP
