How to wire strain gauge directly into SVIM
Advanced Central Logging System including Versatile Input Modules
Postby oz_olly on Thu Mar 10, 2011 8:57 pm
I have an upcoming project where I would like to wire a full bridge strain gauge installation (for axial strain) into the SVIM and use the internal amplification capability. From looking at the SVIM spec sheet and ACL help, as far as I understand I can have an excitation voltage of either 5V or 10V and wire the bridge measurement points into differential voltage inputs. Can you let me know whether or not my understanding is correct?
What do I have to do to ensure that my reading does not go outside the common mode voltage range?
Cheers
Michael Olsen
oz_olly
Re: How to wire strain gauge directly into SVIM
Postby DarkHelmet on Tue May 15, 2018 6:41 am
I'm bumping this back up as I had the exact same question- to the OP did you ever try this out?
DarkHelmet
Postby adrian on Tue May 15, 2018 9:58 am
The method stated by the OP is the correct way of wiring a bridge strain gauge into an SVIM. When you configure the input pin in the software you have to make sure the voltage range (and hence resolution) is set appropriately depending on the voltage range of the bridge.
Return to ACL and VIM
