ADL2 to M130 Custom CAN Message (need help)
Postby mr2andy on Wed May 09, 2018 2:40 am
Hello all,
I have watch the Motec CAN youtube video but somehow I'm still missing something. I'm trying to send a few information from the ADL2 to M130 and keeps running into issue.
Information to be sent from ADL2 to M130
-GPS information
-Switches (Boost Trim and Calibration Trim)
-Wheel speed sensors
CAN setup screen 3.JPG (48.72 KiB) Viewed 18616 times
CAN setup screen 2.JPG (47.99 KiB) Viewed 18616 times
CAN setup screen 1.JPG (40.06 KiB) Viewed 18616 times
mr2andy
Re: ADL2 to M130 Custom CAN Message (need help)
Postby mr2andy on Wed May 09, 2018 2:42 am
Based on the setting I have in ADL2, in M130 under the front wheel speed sensor input, which CAN message and offsets should I be selecting? ;)
M1 Wheel Sensor - CAN setup.JPG (104.49 KiB) Viewed 18615 times
CAN setup screen 4.JPG (48.68 KiB) Viewed 18615 times
mr2andy
Postby David Ferguson on Wed May 09, 2018 3:10 am
The GP Packages don't decode compound messages. You need to be transmitting individual messages with the appropriate address. Now 0x680 is aready in use with the GPS_to_M1 templates (posted on this forum, but I included them below), so for your wheelspeeds, and boost settings, you need to use something different. I chose 0x500 in the files attached to the next posting
Comms template files:
GPS_to_M1_0x680_Version 1.CC7
(8.12 KiB) Downloaded 1438 times
GPS_to_M1_0x681_Version 1.CC7
(8.12 KiB) Downloaded 1460 times
GPS_to_M1_0x682_Version 1.CC7
(8.12 KiB) Downloaded 1736 times
Postby mr2andy on Wed May 09, 2018 3:12 am
David,
Is there a documentation out there showing what CAN address has been predefined for the GP package?
mr2andy
Postby David Ferguson on Wed May 09, 2018 3:13 am
Here are the templates for your wheelspeeds and boost settings
M1 Transmit Wheelspeeds 0x500.CC7
(8.12 KiB) Downloaded 1799 times
M1 Transmit Boost+Cal 0x501.CC7
(8.12 KiB) Downloaded 1495 times
Postby David Ferguson on Wed May 09, 2018 3:14 am
mr2andy wrote:David,
See the help in M1 Tune for "GPS CAN ID Base. In fact, open the Help->Firmware Help... and serach for "CAN ID", then look each of them -- you will see the PDM default is 0x500 (I transmit things from the dash to both the PDM and M1 on the same CAN ID.
Here is a MoTeC document (found under technical information on the motec.com.au website) on various CAN IDs used by their devices:
http://www.motec.com.au/filedownload.php/CTN0015_motec_can_addresses.pdf?docid=4602
Last edited by David Ferguson on Wed May 09, 2018 3:29 am, edited 2 times in total.
Postby David Ferguson on Wed May 09, 2018 3:21 am
Now to configure the M1 to receive the data at CAN ID 0x500, you configure the ECU Receive as follows:
M1 Tune CAN Setup.JPG (43.69 KiB) Viewed 18612 times
To configure the Wheel Speed Front Left you would use CAN 0 Offset 0 as follows:
M1 Wheelspeed CAN Setup.JPG (35.96 KiB) Viewed 18612 times
Similarly for the others:
Front Right CAN 0 Offset 2
Rear Left CAN 0 Offset 4
Rear Right CAN 0 Offset 6
Boost Trim will be at CAN 1 Offset 0
Calibration Switch CAN 1 Offset 2
Hope that helps.
Postby mr2andy on Wed May 09, 2018 4:10 am
Absolutely! I will give it a try when I get home and report back. Thank you very much! :)
mr2andy
Postby mr2andy on Wed May 09, 2018 4:35 am
Also.. what confused me is that when I was using the address x0680 fo send the GPS data from ADL2 to M1, within M130 for GPS, I can specified the CAN address so I managed to make it works.
What confused me is that when it comes to the wheel speed, I was expecting to be able to specify the Can address just for wheel speed as well.
mr2andy
Postby mr2andy on Thu May 10, 2018 2:23 am
Reporting back.. all is working now. Thanks a bunch David.
mr2andy
Return to ADL, ADL2 and SDL
