by Stephen Dean on Fri Sep 14, 2018 5:12 pm
The Daughter board that is used for the OEM replacement M800 is not designed to cope with the loads required to drive a DBW as the internal tracks are too small. You are also not able to purchase a DBW enable for an OEM M800 if the base vehicle did not come with DBW, this is the same as with Cam Control if the base vehicle didn't have it.
The only way to have DBW with an OEM M800 that doesn't have DBW as standard, such as transplanting a later model engine into an earlier spec vehicle, is by using a DBW4 external controller.
