Filter function in Channel Maths
Postby jcorsico on Wed Mar 07, 2018 11:01 am
Hi - for the ‘filter’ function in Channel Maths, what does the constant do? Is it a number of milliseconds over which the channel is averaged? Or a number samples from the channel that are averaged?
Thanks!
Jon
jcorsico
Re: Filter function in Channel Maths
Postby adrian on Wed Mar 07, 2018 2:46 pm
Hi Jon,
The filter constant is just a number, bigger the number the more filtering etc.
I have attached a spread sheet that shows you exactly how it is calculated. If you change the 'Fc' parameter it will show you what affect different constant values have on the output to a step function.
Adrian McGregor
Filter Maths.xlsx
(19.83 KiB) Downloaded 1058 times
Return to ADL3, SDL3 and CDL3
