Calibration of a custom temp sensor Delphi 12160855
Postby TUF-427 on Sat Jan 13, 2018 5:51 pm
Hey Guys,
Install is progressing well , I need to Calibrate a sensor that's not on the drop down list,
Delphi/GM/Packard 12160855 that I want to use for Engine oil temperature, has a wide range and quick response compared to some.
I have a resistance Vs Temperature Data how do I extrapolate that to the Voltage trace?
Data attached
Thanks in advance
TUF-427
Re: Calibration of a custom temp sensor Delphi 12160855
Postby lflife on Sat Jan 27, 2018 5:01 am
I used to use a very primitive method.I put a mercury thermometer and a temperature sensor in a container filled with oil.Heating, referring to different voltages at different temperatures.Record a voltage at 10 degrees centigrade.
hope this helps!
There is always a time to be brave, even if you have nothing, and you will have to fight for it all.
lflife
Postby adrian on Mon Jan 29, 2018 11:34 am
If you are wiring the sensor into an AT input then there is a 1kohm pull up to 5V.
So Vi = Vs x (R2/ (R1 + R2))
where Vi = The input voltage
Vs = Supply voltage (5V)
R1 = Pull up resistance (1kohm)
R2 = Sensor resistance
As an example at 0deg: Vi = 5 x (37499/ ( 37499 + 1000) = 4.87V
Just create a spreadsheet with all the values then copy them into tune.
