What happens when voltage is applied to the output pins while power to the PDM is disconnected, or if an output voltage is higher than battery voltage?
Examples might include: Towing the car on an open trailer the cooling fans could spin, inducing a voltage.
Connecting the race car's tail lights and turn signals to a trailer connector for towing with a tow bar.
Using two cooling fans, a relay could be used to wire them in series or parallel to switch between high and low speed; when switching from high to low, the fans could briefly be at max RPM while they are connected in series, creating back EMF higher than battery voltage.
Similar to the case with the fans, switching any two speed motor from high to low speed (or simultaneously deactivating the output when the motor speed is switched).
Will this power the PDM on even if the battery is disconnected? Are there negative current limits to avoid damaging PDM outputs when an output is inactive? Can current freely flow backward through an output pin to the battery if that output is active?
Thanks,
Will
