Yamaha FXSHO Kit
Information about MoTeC jet ski installations
Yamaha FXSHO Kit
Postby PeteS on Fri Jan 16, 2009 12:04 pm
MoTeC are proposing a kit for the SHO engine
The Kit would consist of
1 X M400 ECU, including the drive by wire upgrade
Plug in adapter loom
ECU Mount brackets and securing screws
Anyone can fit it and it can be changed over in way under an hour.
We are aiming to supply this with a file that should increase at least 30 HP over the standard ECU
The following items currently do not work from the std ECU
Reverse traction control
All Cruise control functions
No Wake Mode
RPM on the standard Dash
Standard ECU
Std ECU SHO.jpg (129.51 KiB) Viewed 15862 times
M400 Fitted
M400 SHO.jpg (151.34 KiB) Viewed 15880 times
MoTeC Research Centre, Melbourne Australia
PeteS
Re: Yamaha FXSHO Kit
Postby sho off on Thu Jan 29, 2009 4:49 pm
wow mine doesnt look that neat pete any chance you can send me those 2 brackets and bolts :D :D :D
sho off
Return to Jet Ski applications
