Single Cylinder Trigger
Re: Single Cylinder Trigger
Postby Matek0012 on Mon Dec 18, 2017 4:43 pm
Winning
Diesel Engine.rsc2
(64.45 KiB) Downloaded 950 times
Matek0012
Postby Matek0012 on Mon Dec 18, 2017 5:00 pm
So i have now a REF signal
I also have a sync signal
i have got a CRIP which i believe to be correct
the injector and Coil are not cycling.
Diesel LPG.e35
(72 KiB) Downloaded 889 times
Matek0012
Postby Matek0012 on Mon Dec 18, 2017 5:09 pm
the cript is 360 deg out because it is to the next TDC of compression
Sorry that number has since been changed to 175 deg
Matek0012
Postby Matek0012 on Tue Dec 19, 2017 10:38 am
So i have got fuel coming onto the injector but the injector doesnt release fuel when the engine is being turned over
Matek0012
Postby Matek0012 on Tue Dec 19, 2017 11:49 am
updating the latest capture
But i am still getting an error regarding the rev/sync not being synced
im also not getting ANY pulses to the injector or to the coil
Diesel Engine.rsc2
(64.45 KiB) Downloaded 893 times
Matek0012
Postby Matek0012 on Tue Dec 19, 2017 11:54 am
And now this has just happened
Matek0012
Previous
