BBC 4x cam sync sensor setup
Postby otto69 on Mon Dec 04, 2017 10:18 pm
Hi
How do I go about configuring the sync sensor for the BBC 4x position cam sensor ?
This is the EFI Connections kit with 4x cam and 58x crank reluctor.
See attached picture.
Clayton
otto69
Re: BBC 4x cam sync sensor setup
Postby otto69 on Sun Dec 10, 2017 5:48 pm
Any ideas on how to configure this ?
Does the M84 have the ability to read the cam gear config ?
Clayton
otto69
Postby Sean on Sun Dec 10, 2017 6:17 pm
My understanding, from having a quick browse through the EFI Connections web site, is that this kit emulates the late 58x LS cam and crank signal, so therefore I'd guess mode 17, same as a 58x LS. I have no first hand experience of this setup, so I'd recommend confirming with MoTeC directly.
Sean
Postby otto69 on Thu Dec 14, 2017 7:44 pm
Thanks heaps Sean
I did call Motec and they recommended mode 17 as well.
Clayton
otto69
Return to M84 ECUs
Users browsing this forum: Bing [Bot] and 7 guests
