8 Ignition output in M84
Postby EagleEyeMotors on Tue Nov 21, 2017 4:02 pm
If we have 8 cylinder engine that have 8 coil per plug Ignition system how we can connect it with motec m84 ?
EagleEyeMotors
Re: 8 Ignition output in M84
Postby SprinterTRD on Tue Nov 21, 2017 4:06 pm
Simple Either waste spark ( 2 coils per output ) or add a IEX for 8 ignition outputs
SprinterTRD
Postby EagleEyeMotors on Sun Nov 26, 2017 5:25 pm
SprinterTRD wrote:Simple Either waste spark ( 2 coils per output ) or add a IEX for 8 ignition outputs
Thanks for your feedback I will chnge the Igntion system to waste spark
in waste spark every coil is connected to two cylinder, my qustion In which cylnider each coil are connected ?
EagleEyeMotors
Postby Stephen Dean on Mon Nov 27, 2017 8:50 am
You need to connect the cylinders that fire 360 degrees apart for waste spark, the easiest way to work out which cylinders these are is to do a star diagram like this, and use the joined cylinders in waste spark.
Waste Spark.png (7.15 KiB) Viewed 9916 times
Return to M84 ECUs
