Converting M150 Package to M190 Package
Postby Herrubermensch on Sun Nov 12, 2017 9:16 am
I have an M150 package that I want to run on an M190. I tried comparing in M1 Tune, and that does not work. Am I relegated to inputting the data manually from M150 package into M190 package or is there some way to migrate data between non-matching firmware?
--Peter
Herrubermensch
Re: Converting M150 Package to M190 Package
Postby adrian on Mon Nov 13, 2017 9:41 am
You should be able to open both the M150 and M190 packages and migrate data no problem.
When you say it doesn't work, what exactly is happening? What packages are you using?
Postby Herrubermensch on Mon Nov 13, 2017 9:55 am
None of the data migrates.
Trying to migrate data from a GPR for M150 to a customized GPR for M190. When I try to do so, none of the data shows up. All null.
--Peter
Herrubermensch
Postby Herrubermensch on Mon Nov 13, 2017 9:58 am
Low and behold, it worked. I must have done it ten times, and the data never migrated. This time, it did.
--Peter
Herrubermensch
Postby PEI330Ci on Sun Nov 19, 2017 10:00 pm
What's going on here? :o
PEI330Ci
Postby Herrubermensch on Mon Nov 20, 2017 12:06 pm
PEI330Ci wrote:What's going on here? :o
LOL. Just making good use of my M190 on the E46 M3 racecar!
--Peter
Herrubermensch
