I'm going to be using an M800 and SKM with my 7M-GTE motor.
The motor has three position for a knock sensor, the middle one us used by the N/A version of the motor which only ran a single knock sensor and the front and rear positions which are used by the turbo version which ran two knock sensors.
As I am restricted to using a single sensor with the SKM is there a particular position on the block I should be using and any suggestions for sensor type?
