SKM Knock Sensor Position - Inline 6 Motor
SKM and OKM
Postby HKS_TRD on Tue Nov 07, 2017 8:18 am
I'm going to be using an M800 and SKM with my 7M-GTE motor.
The motor has three position for a knock sensor, the middle one us used by the N/A version of the motor which only ran a single knock sensor and the front and rear positions which are used by the turbo version which ran two knock sensors.
As I am restricted to using a single sensor with the SKM is there a particular position on the block I should be using and any suggestions for sensor type?
HKS_TRD
Re: SKM Knock Sensor Position - Inline 6 Motor
Postby Scott@FP on Thu Nov 09, 2017 10:13 am
Just use a single and adjust gain and offset for each cylinder.
Scott@FP
Postby HKS_TRD on Thu Nov 09, 2017 6:36 pm
Thanks for the advice.
Which position on the block should I be mounting it, front, rear or middle?
HKS_TRD
Postby Scott@FP on Fri Nov 10, 2017 1:47 am
Any, the gain and offset make up for mounting position, but best bet would be a central location. If the sensor is mounted between 3 and 4 you may end up with a gain table that looks like this-#1 1.04 #2 1.01 #3 .98 #4 .98 #5 1.01 #6 1.04. It doesn't always end up symmetical and even, sometimes the correct gain can seem weird.
Scott@FP
Postby HKS_TRD on Fri Nov 10, 2017 8:42 am
That makes sense especially seeing as Toyota used the centre position for the N/A which ran a single knock sensor.
I was going to use a GM blade type sensor instead of the standard Toyota piezo type or whatever it is
HKS_TRD
Postby SprinterTRD on Fri Nov 10, 2017 1:07 pm
You would be better off using the Toyota sensor as its characteristics will be matched to the engine.
SprinterTRD
Postby HKS_TRD on Fri Nov 10, 2017 2:33 pm
I've been told that once you bore the motor the harmonics change and it isn't as effective plus its such an old sensor the newer GM one would work better as its a different style of sensor
HKS_TRD
Postby Scott@FP on Fri Nov 10, 2017 5:35 pm
Better yet is the Bosch 'wideband' unit. VW/Audi etc.
Scott@FP
Postby HKS_TRD on Fri Nov 10, 2017 9:51 pm
I'll have to look into that, how does it mount to the block?
HKS_TRD
Postby Scott@FP on Fri Dec 01, 2017 12:05 pm
8mm stud mount I believe, its been awhile.
Scott@FP
Return to Knock Modules
