CDL3 Dash vs. Megasquirt 1 ECU
Postby ProBike on Fri Sep 29, 2017 5:35 pm
Is it possible to get the CDL3 dashboard to communicate with Megasquirt Ms1 ECU?
Or should it be Ms2, who has canbus ??
Ps: Ms1 and Ms2 have RS232 seriel port.
Best regards Henrik Rs.
ProBike
Re: CDL3 Dash vs. Megasquirt 1 ECU
Postby adrian on Mon Oct 02, 2017 10:02 am
Unfortunately the CDL3 does not support the MS1 RS232 communications protocol.
The CAN configuration in any of our current dashes (including the CDL3) is extremely configurable, you will be able to set it up to read the CAN communications from a MS2 reasonably easily.
Adrian
Postby ProBike on Mon Oct 02, 2017 8:03 pm
adrian wrote:Hi,
Adrian
Hey
Many thanks for the reply.
Then we have to install a Ms2 cpu :-) to get the canbus solution.
Should we also have: CAN ECU to Display Loom (Part No: # 61198)
to make it Work, or can we use the RS232 cable (Part No: # 61199) ?
Do you have a form of guide, to install CDL3 software up to the Ms2 CPU ?
ProBike
Postby adrian on Tue Oct 03, 2017 11:22 am
Neither of those two looms are really suitable for what you require. All you need is two wires twisted together with terminating resistors at each end. If you have a look at the CDL3 User Manual it has example wiring diagrams of how to wire a CAN bus.
In terms of setting up the CDL3, if you can get information on how the CAN is formatted out of the MS2 I can show you how to set it up.
Postby ProBike on Thu Oct 26, 2017 12:06 am
Hello.
Then I finally upgraded my ECU, from Ms1 to Ms2, which supports the CAN bus.
But can not get CDL3 to talk to Ms2 ECU, can not even see it under connection settings :-(
Some good suggestions, possibly a boot file for CDL3?
ProBike
Postby David Ferguson on Thu Oct 26, 2017 11:11 am
You should be using 11 bit CAN support (MS2/Extra 3.4.x). This document tells you how to setup the MS2 and has the information needed to create a CAN Comms Template for the CDL3 (note the 500 kb/s bus speed).
http://www.msextra.com/doc/pdf/Megasqui ... adcast.pdf
and there is a DBC file if Adrian has a converter...
http://www.msextra.com/doc/pdf/Megasqui ... -10-27.dbc
Postby ProBike on Thu Oct 26, 2017 5:22 pm
Thank you for the answer David :-)
Keep it up, it looks intricate, in my sense :shock:
Hope Adrian understands more of it, than I do :?:
ProBike
Postby adrian on Fri Oct 27, 2017 4:53 pm
If you take a look at the PDF David posted it has a list of all the available channels on the bus. If you let me know which ones you actually want I can show you how to set them up in the Dash.
Unfortunately there isn't any way to import the DBC file directly into CDL3 Manager so it will have to be done manually.
Return to ECU to Dash Comms
