I am in the process of wiring and programming a stroked and blown 5VZ engine and need to verify the CRIP. I have determined that it is about 507 degrees. The timing gear is a 36 tooth with two missing teeth. The cam is a 72 tooth sprocket with one tooth each revolution. If anyone has the proper settings for the cam and crank sensor I would appreciate it. It's my understanding that Toyota uses magnetic sensors for cam and crank and that they are falling signals.
I am also looking to the dwell settings for the Toyota 4.7 liter engine. I am using these integrated COPs on this engine to allow individual cylinder tuning. i am planning to start with 2ms and do not have a scope to check for current limits.
