M1 Build - Port Injector Module -- Contribution Inputs
Postby Fast_Moto on Fri Mar 17, 2017 2:08 pm
What is the difference between the Contribution Input Object and the Contribution Main Input Object. The descriptions differ only in the first word: "The percentage of total fuel required delivered by these injectors" v. "Sets the percentage of total fuel required delivered by these injectors." Since both are input objects, I am not sure what the difference is between the two. Can anyone elaborate?
P.S. I reviewed how these are used in the GPR packages and adapted a similar working approach for my build. Nonetheless, I would like to fully understand the relationship between these two inputs.
Fast_Moto
Re: M1 Build - Port Injector Module -- Contribution Inputs
Postby aNinjaneer on Tue Aug 08, 2017 11:23 am
I'd imagine the object type for "Fuel Injector [Primary/Secondary] Contribution" is a bug. Contribution should be a channel instead of an input object as a channel, and Contribution Main should be the value you can set as an external table of your choosing.
aNinjaneer
Return to M1 Build
