Jenvey DBW
Jenvey DBW
Postby greenamex2 on Thu Jul 20, 2017 4:13 am
Hi
Looking to use the Jenvey DBW motor on a V6 with ITB (Jenvey) and an M130.
Would it be better to have a dual channel TPS just on the throttle bodies, or a single channel on the throttle bodies and a single channel on the Jenvey DBW motor?
Thanks in advance
greenamex2
Re: Jenvey DBW
Postby stevieturbo on Fri Jul 21, 2017 8:23 am
For obvious safety reasons, there should be dual tracks on both pedal and blade position sensors.
stevieturbo
Re: Jenvey DBW
Postby Merlin on Sun Aug 06, 2017 6:58 pm
I use the BMW version on a Quad Throttle set up
I have the Factory BMW one on the Motor and a Contactless on the throttle Shaft
all works fine
It does take a little time to set all the tables so both are in sync....Ie read the same value through out the range
John P
Merlin
Re: Jenvey DBW
Postby greenamex2 on Mon Aug 07, 2017 6:10 pm
Thanks Merlin
greenamex2
