i2 standard, Y axis manual setting on Time Distance Graphs
Postby Brian on Thu Aug 03, 2017 8:33 pm
Can the Y-axis limits be manually chosen on the time distance graphs? This feature is available when making a gauge ( bar, dial etc). I have found the adjustments for Y-axis offset, zoom and filter, but not manual adjustment of the range.
Thanks,
Brian.
Brian
Re: i2 standard, Y axis manual setting on Time Distance Grap
Postby David Ferguson on Fri Aug 04, 2017 8:28 am
This is setup in the properties of the Time Distance Graph. Right click on the graph and select Properties... Under the channel tab, you can edit the scale of a group, or an individual channel (which may affect it's scale everywhere it's used with Channel/Auto group scaling). Here is a screen shot where I'm changing the scaling for the Fuel Mixture group (Group 5) to show the real area of interest:
Postby Brian on Sat Aug 05, 2017 2:50 am
Hi David,
Yep, works.
Great, thanks,
Brian.
Brian
