CAN Inputs
CAN Inputs
Postby uaeproz on Fri Jul 14, 2017 9:06 am
Hey guys,
I have a question for dummies. I have M150 GPRP tune package + PDM 30. I just want the CAN inputs help for:
------ Gear Neutral Switch
I need to know:
-- Can Message:
-- Offset:
-- Data Size:
-- Alignment:
-- Mask:
-- Divisor:
------ Clutch Switch
I need to know:
-- Can Message:
-- Offset:
-- Data Size:
-- Alignment:
-- Mask:
-- Divisor:
------ Clutch State
I need to know:
-- Can Message:
-- Offset:
-- Data Size:
-- Alignment:
-- Mask:
-- Divisor:
I’d appreciate any support.
Many thanks,
Abdulla
uaeproz
Re: CAN Inputs
Postby Stephen Dean on Fri Jul 14, 2017 11:03 am
Hi Abdulla,
I have attached a document explaining the process, and a PDM template that matches the document. The channels that you are after are setup in the attached config.
M1 PDM Communications.pdf
(1.28 MiB) Downloaded 1587 times
M1 Feb2016 CAN Messaging.pdm
(78.16 KiB) Downloaded 1326 times
Re: CAN Inputs
Postby uaeproz on Fri Jul 14, 2017 10:53 pm
SDean wrote:Hi Abdulla,
Thank you so much. This is very helpful
uaeproz
Re: CAN Inputs
Postby uaeproz on Sat Aug 05, 2017 11:38 am
Hi Stephen,
Can you post PDM to Dash communications instructions? Also if you have messaging.pdm for that, it would be awesome.
Many thanks,
Abdulla
uaeproz
Re: CAN Inputs
Postby adrian on Mon Aug 07, 2017 10:12 am
The PDM has default messaging that you can simply load templates into the Dash to read, see below (PDM setup on the left, Dash on the right):
Default PDM CAN Messaging.png (40.2 KiB) Viewed 15785 times
