Hey guys im trying to get the ABS sensors from my 2012, E90 M3 to work on a universal digital input.
but dont even get any readings in the oscilloscope function any idea?
Not sure if the Threshold and hysteresis values are correct
Ben-S wrote:They work just fine, you just need to wire them with a pull down resistor. If you're keeping the ABS module there are also redundant wheel speed output pins on the unit.
Ben-S wrote:Yes I have. I'll look through my notes to see exactly what I did. Can you clarify what you mean by "a whole pulse width, not a single pulse"?
