Nissan Ign Module Placement???
Includes MoTeC CDIs, Ignition Expanders
Postby Stuie38 on Thu Jan 08, 2009 12:25 am
I have a CA18DET and have just fitted a bigger turbo and new exhaust manifold.
The problem I have is that the ign module is now sitting really close to the exhast manifold.
I'm worried about heat on the ign module, so I'm going to move the module.
Due to limited space in the engine bay I was thinking of mounting the module in the cabin beside the ECU.
Is there a maximum wire distance between the module and the coils?
Will this extra wire cause a problem???
Stuie38
Re: Nissan Ign Module Placement???
Postby RossB on Thu Jan 08, 2009 8:47 am
Moving the module in to the car beside the ECU should not cause any problems. The length of the wiring is not critical just ensure that your Ref/Sync wiring is properly screened to reduce the likelihood of any electrical noise interference.
RossB
Postby Dragon on Thu Jan 08, 2009 12:32 pm
Placing the ignition module inside the passenger compartment is not a problem at all.
We have been doing it for years on our race cars.
Dragon
Return to Ignition systems
